Topic: replacing dash harness in 1936 ford question
hotroddoc    -- 03-08-2025 @ 10:27 AM
  I'm replacing the dash harness in my 36 coupe as well as converting to 12 V negative ground. My question is how does one run the new wire through the Amp gauge? It seems to have a closed loop behind the gauge. And, do I have to run it in the opposite direction since I am changing the polarity?
Thanks!
carcrazy    -- 03-08-2025 @ 9:10 PM
  Yes, that is exactly what you have to do. Simply reverse the loop of wire on the back of your amp gauge.
hotroddoc    -- 03-09-2025 @ 5:30 AM
  Thank you!
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=17483
