| Catfish Jones | -- 01-30-2025 @ 9:46 AM |
Good afternoon This question is in reference to an all original 1938 Fordor Deluxe. My emergency brake works very well when the handle is operated. When I pull the handle, I see that the brake pedal is also moving down, as if being depressed with my foot. I found out the hard way at a car show the problem with this is the brake lights are now illuminated and ended up with a dead battery. My question is, is this how the E-brake was originally designed to work?
| MG | -- 01-30-2025 @ 10:04 AM |
Your brake pedal return spring is broken or missing...
| Catfish Jones | -- 01-30-2025 @ 10:11 AM |
Thanks MG, that makes perfect sense. Is the brake return spring available as a reproduction?
| trjford8 | -- 01-30-2025 @ 10:17 AM |
Check with the V-8 vendors on the return spring. Check the links page in the left column of this site and it will show vendors. This message was edited by trjford8 on 1-30-25 @ 10:18 AM
| Catfish Jones | -- 01-30-2025 @ 10:19 AM |
Thanks very much for the help!
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=17417 |
