| clint@abcsecurity.co.za | -- 01-06-2025 @ 5:13 AM |
Hi all, need some advice on our '36 Ford sedan we purchased. In reverse there is a very bad shudder when the clutch is released, and continues shuddering while you reverse. Going forward there is no shudder. Any advice?
| kubes40 | -- 01-06-2025 @ 5:58 AM |
Being it shudders in reverse only; it's probably not a clutch issue. Check to be certain engine steady rods are in place and tight. Engine mounts fresh? Transmission mount fresh? Mike "Kube" Kubarth
| carcrazy | -- 01-06-2025 @ 9:57 AM |
In addition to the items previously mentioned, check the rear shock links to make sure there is no play in the connections to them.
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=17394 |
