| chucky | -- 11-13-2024 @ 1:31 PM |
I mounted a cooing fan on the front of the radiator on my 36 ford. It is blowing the wrong way. I plan on reversing the polarity. Do I have to switch the fan blades around. Thanks...
| ford38v8 | -- 11-13-2024 @ 6:11 PM |
Not the answer you wanted, but if and when you get it working, you should know that a front mounted fan is considerably less efficient than a fan pulling from behind. Alan
| carcrazy | -- 11-13-2024 @ 7:37 PM |
These instructions from Fifth Avenue Internet Garage should answer all your questions about your electric cooling fan. The message from ford38v8 is correct, a "puller" fan is much more efficient than a "pusher" fan. Using the fan to pull the air through the radiator is the best bet provided you have the room to package the fan between the radiator and the engine. https://www.fifthaveinternetgarage.com/pdf/coolfan_install.pdf
| chucky | -- 11-13-2024 @ 7:41 PM |
thanks guys, I appreciate it
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=17310 |
