| silverchief | -- 08-24-2024 @ 11:59 AM |
One headlight in my stock 46 coupe is out. What is the best way to determine if it is the bulb itself, or a problem in the wiring serving the headlights. Thank you.
| Kens 36 | -- 08-24-2024 @ 12:27 PM |
Is it out both dim and bright? Ken
| jerry_356 | -- 08-24-2024 @ 1:06 PM |
Test the bulb and/or the socket with a multimeter. The socket should show 6 v. for both high and low beam. On the bulb, each beam should read about an Ohm or less . If the filaments are shot they'll read infinity. The other choice would be to swap bulbs and see what happens. That would determine if you're getting voltage to the bulb.
| silverchief | -- 08-24-2024 @ 2:02 PM |
Thanks very much guys. That should do it!
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=17193 |
