| denofiniquity | -- 05-25-2022 @ 10:12 PM |
Hey you guys. I have in my hand here a Ford 94 carb, List 713N. I am in need of at least the correct accel pump and correct gasket set. All kits I have seen listed, do not contain this type pump, which uses the round shaft pump, not the flat shaft pump. I have of course been Googling for cple hrs, with no luck. By the way, this carb came from a 50's Flaty, and will be used on a 50 pickup. Any body?
| mfirth | -- 05-26-2022 @ 4:36 AM |
You might try N A P A But, try Charlie NY on the Ford Barn. He is a master of our 94 type carbs.. Third Gen or Vanpelts would be good sources too.
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=15697 |
