Topic: Instrument Cluster LED
JayChicago    -- 05-20-2022 @ 9:34 AM
  Found a 6-volt, non-polarity LED that will fit in my '40 instrument cluster. Problem is little depth available in the cluster, requires a snub-nose LED. Not sure if same problem occurs with other years. This short LED worked:
https://www.amazon.com/gp/product/B07JLLKXRD/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&th=1
Edit: it appears to be dimmable, so far seems to work ok dimmed down. The little LED throws plenty of light, I may actually use the dimmer now.
This message was edited by JayChicago on 5-20-22 @ 10:05 AM
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=15678
