Topic: 1940 Ford Coupe Glass
V8JR    -- 05-18-2022 @ 9:59 PM
  Any hints or tips on removal and installation of the side quarter windows in a 1940 Ford Coupe.
kubes40    -- 05-19-2022 @ 6:03 AM
  These are perhaps the easiest to R&R.
Remove the molding, remove the glass.
If you are replacing the glass, you may find it significantly thinner than the authentic glass. If so, add some electricians tape (enough to make up the difference of thickness) to the edge prior to installing the rubber gasket.
TomO    -- 05-19-2022 @ 7:49 AM
  Here is a link to the procedure:
http://vanpeltsales.com/FH_web/flathead_glassinstall-40-46_pg1.htm
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=15677
