| Gary M. | -- 05-14-2022 @ 11:13 AM |
Hi guys, im installing front armrests on my 39 standard which did not come with the car originally. The interior was replaced years ago with a lebaron bonny interior. Im hoping that the backside of the door panel has markings for drill holes for an armrest, but if it doesnt , id like to look at a drawing that shows the install. Does anyone have a pic that they can post ? Thanks...
| 1931 Flamingo | -- 05-15-2022 @ 11:40 AM |
If you remove the door panel you should see the screw holes. Paul in CT
| trjford8 | -- 05-16-2022 @ 6:51 AM |
If it's an older LB kit the screw holes are probably already there for the arm rests. Even though the standard did not come with the right side arm rest I think LB used the same panels(patterns) from the 38 deluxe.
| Gary M. | -- 05-20-2022 @ 4:06 PM |
Thanks guys. Hope the holes are in fact on the back of the door pannel .
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=15667 |
