Topic: Oil Pan
silverchief    -- 09-30-2020 @ 9:13 AM
  My 46 coupe flathead V8 has a 49 engine. Heads stamped AB not RT as if truck engine. Holley carb..
The oil pan has a clean out plate., held on by about eight bolts. I assume the guy who restored it put a truck oil pan on, specifically for the purpose of being able occasionally clean out sludge.
The plate gasket is oil soaked and I would like to replace it. Macs is the only place with anything close and it specifically states it is for a six cylinder engine, truck, and appears to have fewer bolt holes.
Suggestions please.
kubes40    -- 09-30-2020 @ 9:44 AM
  You can buy gasket material at Napa - cheap. Make a new gasket - easy enough to do.
TomO    -- 09-30-2020 @ 10:44 AM
  The 48-53 clean out plate gasket for the 6 cylinder and the 239 V-8 have the same P/N, so Mac's gasket should fit.
silverchief    -- 09-30-2020 @ 1:36 PM
Thank you. Just changed the oil so next one will be next year - but I will order the gasket now.
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=14205
