| JohnA | -- 07-12-2020 @ 1:26 PM |
Hi Guys. I recently picked-up a remote control starter switch which has two wire leads. One positive and one negative which one goes where??? Johna
| TomO | -- 07-13-2020 @ 8:19 AM |
On a stock 6 volt solenoid, one clips on to the center contact of the solenoid and the other clips onto a good ground. It is not polarity sensitive. Tom
| JohnA | -- 07-13-2020 @ 12:09 PM |
Thanks Tom--I have a 12 v solenoid with two small terminals,also should I disconnect alternator.Johna
| TomO | -- 07-14-2020 @ 6:46 AM |
If =you have the 2 terminal starter button, you need to supply 12 volts to the S terminal. The hook up would be one lead to a 12 volt source and the other lead to the S terminal of the solenoid. A remote starter switch should not affect the alternator. Tom
| JohnA | -- 07-14-2020 @ 9:36 AM |
What would I do without you guys. Thanks Johna
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=14000 |
