leazer 48
-- 05-23-2020 @ 8:39 AM
I am adding front door panels (upholstery) to my 48 coupe, holes are in the door for the clips, but need a dimension from the bottom row of holes to the bottom of the door panel so the fit is right, I have the panel but no holes, can any member help?
-- 05-23-2020 @ 3:15 PM
The clips are off set. Make a paper pattern of the door and hole locations. Then use a clip to measure the off set for the panel holes.
leazer 48
-- 05-26-2020 @ 6:05 PM
How much of a offset, I have to miss the bottom door seal or the door want shut good, carpet on door panel skin will interfere.
-- 05-27-2020 @ 6:19 AM
If you have the clips you can measure the off set.
