| JohnA | -- 04-14-2020 @ 1:25 PM |
I converted my 48 sedan to 12 volts couple years ago and it still has the old 6 volt ground cable (web type), can I use 1 or 2 gauge newer cable for ground, also I have one of those green knob battery disconnects, does it matter if it goes on pos of neg battery post. Johna
| 51woodie | -- 04-14-2020 @ 3:44 PM |
JohnA. The old “braided” cable I good for 12 volt use, unless it is in poor condition. The “green knob” isolator goes on the negative post.
| JohnA | -- 04-14-2020 @ 5:12 PM |
yes, old braided cable clamp end is in bad shape, won"t tighten up.
| TomO | -- 04-15-2020 @ 7:50 AM |
The battery disconnect should always be installed on the grounded side of the battery. Tom
| JayChicago | -- 04-15-2020 @ 9:11 AM |
Tom I'm curious about the theory behind this. Why is it better to use the grounded side?
| TomO | -- 04-16-2020 @ 7:21 PM |
Jay, it is just a safety precaution. when you are disconnecting or connecting on the supply side and your wrench touches a ground, you will have lots of sparks. Also the frame and engine are a single source for ground, if something contacts a supply side connector, it cannot complete a circuit. Tom
| MGG | -- 04-16-2020 @ 8:06 PM |
All of the green knob types of disconnector switches that I have seen are made to fit on the negative battery posts. Does anyone know of any which fit on the positive posts?
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13751 |
