| Newms | -- 02-05-2020 @ 10:15 AM |
Does anyone have any experience with the Stromberg electronic ignition for a '37 90HP?
| supereal | -- 02-05-2020 @ 12:53 PM |
Many aftermarket ignition systems suffer from poorly regulated voltage in older cars, as well as being heat sensitive under the hood. The stock Ford ignition system is one of the most effective and durable systems. Unless you are racing, or have other unusual uses, the electronic systems probably don't offer much, if any improvement. Over the years at our shop, we have removed several of those when troubles showed up.
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13582 |
