| acereske | -- 12-06-2019 @ 4:38 PM |
36 Ford fordor has a speedometer that registers speed but the odometer does not function
| fenbach | -- 12-06-2019 @ 7:17 PM |
try pushing in on the trip odometer reset shaft
| ken ct. | -- 12-06-2019 @ 8:30 PM |
Its a small shaft that sticks out the back of meter. Ken ct
| 40cpe | -- 12-06-2019 @ 8:36 PM |
On my '38 the shaft pushes IN to reset, pull OUT to count miles.
| 37RAGTOPMAN | -- 12-14-2019 @ 2:40 PM |
as far as I can remember that shaft behind the speedometer only sets the trip back to zero, or you can set the trip has nothing to do with the odometer itself one thing I did find out the 3 number is a standard car,and trucks only reads up to 99 while Deluxe cars have 4 numbers and goes up to 999 35 39 cars, trucks you will have to have the speedometer looked at, easy to remove, maybe just a simply lubing might help or a loose screw ? easy to take apart, just be careful with the parts, my 2 cents 37Ragtopman
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13429 |
