| smokinjoe | -- 05-28-2019 @ 12:46 PM |
Hi I am going to be replacing the vent window and rear window seals on my 41 ford sedan coupe. Does anyone know where I can find the rivets ( I believe ) that go in the exterior hinge. Thanks Joe
| supereal | -- 06-01-2019 @ 12:03 PM |
I have used a "pop rivet" for the front wing window pivot. Choose a size for the hole, make a shim between the bracket and the window that will be removed after the rivet is installed. This is necessary so the pivot will not be locked by the rivet when it is "popped".
| TomO | -- 06-01-2019 @ 12:16 PM |
Check your local hardware store. That's where I found a stainless one to do my vent windows. Tom
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=12942 |
