| Garrison202 | -- 05-28-2019 @ 12:27 PM |
Hello All! Thanks to your help, I finally found my Phaeton's serial number (2856239) and got it insured. Now I'm filling out the application for historical registration. The application has a box where I fill in the car's "Cylinders/Type of Power." I know she has 8 cylinders, but what should I put in this box? Any info you provide will be greatly appreciated. Also, I see another box to enter her "Unladen Weight/Max Gross Weight." Where would I find this? Thanks so Much, John This message was edited by Garrison202 on 5-28-19 @ 12:31 PM
| CharlieStephens | -- 05-28-2019 @ 12:46 PM |
What you put in the boxes depends on where you live and that information is missing from your profile. Best to call your local DMV. The weight information probably only applies to commercial vehicles, but again, call your local DMV. Charlie Stephens
| MG | -- 05-28-2019 @ 1:04 PM |
"Cylinders/Type of Power." V8 should suffice. "Unladen Weight/Max Gross Weight." = 2640 lbs | 1197.484 kg See > https://www.conceptcarz.com/s7512/Ford-Model-68.aspx Be sure to scroll down at the above site.... Deluxe Phaeton Price : $595 Weight : 2640 lbs | 1197.484 kg Seating Capacity : 4 Doors : 4 Exterior Length : 182.8 in | 4642 mm. Height : 68.6 in | 1743 mm. Wheelbase : 112.0 in | 2845 mm. Front Track : 55.5 in | 1410 mm. Rear Track : 58.3 in | 1480 mm. This message was edited by MG on 5-28-19 @ 1:23 PM
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=12941 |
