| Zero | -- 05-24-2019 @ 2:54 PM |
Any tips on removing stubborn rear wheel grease seals? Retainers came out easy enough.
| kubes40 | -- 05-24-2019 @ 5:13 PM |
You can purchase a seal remover reasonably enough. Or, get a wooden dowel and go through the outer hole of the hub and tap against the bearing cage. Mike "Kube" Kubarth
| Zero | -- 05-24-2019 @ 6:51 PM |
Thanks Mike. I've got plenty of wood dowels to use. I'll start there. Thanks again. John
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=12931 |
