Topic: Hot battery cables
jimbomac    -- 05-09-2019 @ 2:56 PM
  I picked up my 53 Sunliner from the winter storage/restoration shop today. They had replaced the oil pan gasket and in the process disconnected the starter power cable. It appeared to be reconnected correctly. The car started very slowly, when I got it home I tested the battery, 6.85 V. It then wouldn't start, cranking very slowly.Lights were bright. Charged it for 2 h, again tested at 6.85. Again cranked very slowly, then wouldn't crank at all. Cranked it for probably 10-15 sec at the most. At that point, noticed smoke and found both of the battery cables red hot and smoldering, and both proceeded to burn away from their connections at the block and starter relay. It is + grnd, and was connected correctly. Any ideas? Bad starter? It's only about 4 yrs old, rebuilt I think. No starting problems before today
MG    -- 05-09-2019 @ 6:10 PM
  Given that replacing the oil pan gasket requires removal of the starter motor, they must have hooked-up the cable to the starter motor incorrectly in that it must be touching a ground - probably at the pan or block....The cable to the starter motor is in contact with a ground somewhere along its length....Inspect where the cable to the starter motor is connected at the starter motor - its connector could be touching the case of the starter motor or the post on the motor is no longer insulated from the case due to over tightening of the nut. Bottom line is this > You have a direct short across the battery when the starter solenoid is energized. You'll have to replace all of the cables involved in the starting circuit plus the solenoid and possibly the starter motor itself needs to be replaced or repaired. The shop where you had the pan gasket replaced scr*w*d up....
This message was edited by MG on 5-10-19 @ 10:43 AM
alanwoodieman    -- 05-09-2019 @ 7:31 PM
  did they change the cables to a smaller gauge? like 12 volt cables on 6 volts, which will melt the cables
sarahcecelia    -- 05-10-2019 @ 6:17 AM
  Hot battery cables show a resistance, (short), somewhere. Bad starter, or it could be hanging up; short in the hot wire to the starter? It runs along the frame cross member under the oil pan, and is probably cracked and needs replacing after 66 years anyway! It is held to the lip on the rear of that cross member, with as I remember, 2 clips. It's about 44 inches long. (The other end is mounted to the solenoid on the driver side inner fender panel) If you are replacing it, REMEMBER TO DISCONNECT THE GROUND CABLE ON THE BATTERY FIRST!! To test the starter motor; Take the starter off, and put it on the floor. Put your foot on it, (otherwise the torque will make it JUMP!!) to keep it in place, positive jumper cable to case where a mount bolt goes, and take the negative cable and just touch it to the stud that the hot cable goes to. The starter motor should spin freely.
Regards, Steve Lee
jimbomac    -- 05-10-2019 @ 12:15 PM
  So we pulled the starter and it was shorted/burned up internally- it's off to the rebuilder. The rest of the electrical system tested ok. Car had a frame off 2 yrs ago and all wiring was replaced at that time. Not sure of battery cable guage, it is thicker than 12 V for sure, but will be going to O now. Thanks for all of the advice!
ford38v8    -- 05-10-2019 @ 4:55 PM
  Jim, Given that the "Storage/Restoration Shop" had replaced the pan gasket, they would also have removed the starter to perform that task. Starter mounting bolts being the only thing preventing the internals from dislocating, and the starter having functioned properly before the "restoration", it is very likely that your restoration shop failed to reassemble the starter correctly, thereby precipitating its internal short. If I were you, I'd view that shop's professional conduct with suspicion if they don't own up to the damage they caused.
JayChicago    -- 05-10-2019 @ 6:48 PM
  “Starter mounting bolts being the only thing preventing the internals from dislocating“
I don’t understand this. Can you explain?
ford38v8    -- 05-11-2019 @ 12:27 AM
  Jay, the starter is held together by two long bolts which double as mounting bolts. The removal of those bolts enables the starter to dismount, and to disassemble itself if not handled correctly.
dandy32    -- 05-11-2019 @ 4:25 AM
  Hey Jim also make sure there is no paint between the starter and the pan it needs to make good electrical contact for your starter to be grounded properly.Just A thought
51woodie    -- 05-11-2019 @ 5:12 AM
  Here is a link to a YouTube video that shows a Ford tractor starter being worked on. The remove/install will be the same on your car.
https://www.youtube.com/watch?v=IlfqBVW2Q2M
LarryK    -- 05-12-2019 @ 8:22 AM
  I am not sure my comment is applicable to your 1953 car, but cars from 1932 through 1948 have a starter mounting bracket that helps to support the starter and thus maintain its proper alignment. The basic part number is - 11140. One end attaches to the starter under the head of the through bolt closest to the engine. The other end attaches to the engine block using the nearest oil pan bolt. Since the oil pan was removed, the shop may have failed to replace this bracket upon reassembly.
Larry
Larry
therunwaybehind    -- 05-12-2019 @ 8:53 AM
  I have not worked with lead acid batteries used for primary use in a time and so I only know recent trickle chargers. Would they allow a battery to be charged with only 6.85 volts, open circuit? I am not sure. Each cell of a lead acid battery should have 2.2 volts. This is just basic chemistry. Next is hygrometer reading which is the concentration of acid and usually measured with a little diver in a glass tube that sucks up acid out of the cell. Now, recently some batteries are gel type with rolled up plates and so maybe not chance to use an old fashioned hygrometer.
The battery chargers of the 50's and 60's had a load test where you could read the voltage of the battery under load to explore internal resistance. This is where you might see a reading like 6.85 volts and it be OK. Power to the motor is volts times amps so if it is delivering a lot of amps the volts may go down. Batteries are rated in ampere hours so you can guess at how long you can crank at a given amperage before the voltage is insufficient to continue. Even though batteries will not usually give you a shock be careful if you are sweaty. I looked up some of Michael Faraday's papers at the Royal Institute to explore more fully the issue of positive ground where J.J. Thompson discovery of the actual charge carriers being electrons, with negative charge, that move on the surface of a wire while positive ions move in the electrolyte of the battery to charge and discharge it.
I had looked for some technical expertise on life of ferromagnetic materials in terms of not being a useable core for an electromagnet so simply rewinding could reestablish a part. I already knew that replacing the brushes which for starters usually out last several generators was not successful. If this is too deep, please do ask for diminished content. Don't forget the little braided ground from the engine to the firewall. The key words in working with armatures and fields are "fine magnet wire" and "varnish insulation" not gauge zero battery cable with heavy rubber insulation like for a remote battery in the trunk. Most of the power inside the motor or generator is in magnetic fields and thus "in the air". It is not in an arc as might happen with bad brushes but rather in lines of flux that loop between North and South poles of the magnetic cores and their electrical windings. As an aside, can I have an side here? or will it be considered off topic? Could one of those security wands that gate keepers use at sporting events and music venues be as useful as a "growler" to determine magnetic state of a disassembled part?
This message was edited by therunwaybehind on 5-12-19 @ 9:14 AM
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=12892
