| merc8 | -- 04-25-2019 @ 1:40 PM |
hi there, could somebody tell me the spline count on my 1946 mercury 8 sedan's pinion, i believe it's either 6 or 10. i'm considering purchasing a ring @ pinion kit with a lower ratio to get better cruising without the motor revving too high, cheers murray. cheers murray
| 42merc | -- 04-25-2019 @ 5:08 PM |
6 spline pinion.
| merc8 | -- 04-25-2019 @ 7:38 PM |
ok thank you for that, cheers. cheers murray
| supereal | -- 04-30-2019 @ 10:51 AM |
There are available adapters to bridge the gap between the early and late splines. C&G sells them, along with the required coupler pin.
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=12847 |
