| hardtop25 | -- 01-26-2019 @ 12:58 PM |
What is the differential ratio? I'm running the '41 Lincoln in my vintage dirt track car ('39 Ford coupe). Was told ratio is 4:41. My experience is that it is too low for my use. Are NOS or after market ring&pinion sets available for conversion? Thanks.
| TomO | -- 01-28-2019 @ 7:45 AM |
4.33 and 4.44 ratios were used in the earlier Zephyrs. I can't find the ratios used in the 41 Zephyrs, but 4.41 sounds reasonable as overdrive was on most of the cars. You will probably find it very difficult to find a replacement gear set and would be better off finding a Ford differential for your car. There are gear sets that would be more suitable for your use. A 3.78 is a pretty common standard ratio for a Ford and 3.54 gear sets were also used. Tom
| hardtop25 | -- 01-29-2019 @ 11:03 AM |
thanks Tom. Will a Ford center section mate up to the Lincoln axle housings and torque tube?
| TomO | -- 01-29-2019 @ 7:31 PM |
I don't think the axle housings will mate up, but I am not sure. Why don't you want to swap in a complete rear end? Tom
| hardtop25 | -- 02-04-2019 @ 12:36 PM |
I would like to locate a complete unit for straight swap. But in case I need to piece things together just wondering which components are compatible.
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=12644 |
