rayfry
-- 01-11-2019 @ 6:42 AM
Just purchased a 1949 Ford with a Flathaed V8 and 2 Strombergs. Does it matter which carburetor is the primary and also the manual choke is connected to both carburetors. Should the choke be only connected to one carb?
ken ct.
-- 01-11-2019 @ 8:42 AM
There is NO primary or secondary. They both work in unison. Choke can be used on 1 carb only (your choice) omo ken ct.
ken ct.
-- 01-11-2019 @ 8:48 AM
Just noticed a 49,this engine needs a vacume sourse for the dist,usually from a diff carb (8BA) 94 holley or ford carb.Normally wont run right with stroms .Call me for more info 1-203-260-9780
ken ct.
-- 01-11-2019 @ 9:00 AM
rayfry
-- 01-11-2019 @ 9:58 AM
If I use the choke only on 1 carb. should I remove the butterfly on the other carb?
JT Ford
-- 01-12-2019 @ 3:08 PM
No reason to remove the butterfly.
