Fred | -- 03-26-2010 @ 3:37 PM |
Does anyone know if the '53 sychro 4 speed truck transmissions has a 10 spline output shaft or what transmission does? Thanks, Fred
supereal | -- 03-28-2010 @ 10:33 AM |
Consult any truck "power train" shop in your area. They will know, if you can locate any manufacturer or model number on the transmission. Ford used a number of vendors, such as Dana, New Process, and others, depending upon the order of the dealer. If you are mating a transmission to a drive shaft, yokes are available to modify the piece.
double de | -- 03-16-2011 @ 2:30 AM |
i am looking to put new drive shaft on my 49 f1 running the 3 speed tranny is there a website to go to help me out thanks de
supereal | -- 03-16-2011 @ 9:52 AM |
Usually, a driveshaft has to be made up for the application. We use a long bed lathe with a steady rest to make up the tube, and to weld the ends, so it takes a machine shop with the right equipment to do it. We lengthen and shorten truck chassis, which requires a change in the drive live. Look for a big truck shop in your area if there is no machine shop.
bonusbuilt1950 | -- 03-16-2011 @ 10:28 AM |
The only 4 speed for 53 is the T-98, has a case marking of 4TE on it. Part number of the output shaft is B9C 7061-D, it lists it as 14-43/64 inches long and has 10-10-10 straight splines. Barry 50 F-1
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=987 |
