denofiniquity | -- 01-23-2014 @ 5:17 PM |
Hey guys, I have exhausted my sources for these "bolts" There are 3 for each spring set. So 6 up front. They are 1 inch in dia. and length of that part is 1.910". The actual bolt through the center is 3.840", which is the actual "bolt" with threads on both ends, (7/16 fine) and a hex formed between the threads and the 1" dia part which is what is actually pressed into the 1" spring eye. I have tried Mac's, Drake, Benz Spring and others. Please! No sense having new springs made if we cannot mount them. Trucks are 40 & 41 3/4 ton pu's. Not to be confused with 1/2 ton. This message was edited by denofiniquity on 1-23-14 @ 8:38 PM
alanwoodieman | -- 01-23-2014 @ 8:13 PM |
you need to try Joblot in NY, I think the pieces you are looking for are actually called spring shackle studs, 01Y-5463 3/4 and 1 ton 40-41, 8.95 ea. stud bar 01Y-5468
denofiniquity | -- 01-23-2014 @ 8:40 PM |
Thanks Alan. You might look back at my message as I had to change a cple of the dimensions. Dennis
alanwoodieman | -- 01-24-2014 @ 5:15 AM |
your incorrect dimensions doesn't matter, I gave you the part numbers, so be happy
denofiniquity | -- 02-03-2014 @ 12:42 PM |
Thanks for helping. Tried Joblot, as well as many others. Each one led to another. Finally found the right parts from "1/2 Ton Fun" in New Jersey.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=6945 |
