PeterFord | -- 05-13-2012 @ 2:57 PM |
Mine seems to lose oil. There appear to be two pin holes in the reservoir base thru which oil disappears into the housing of the breather. Is this normal? I thought the oil pool was just what you can see when you take off the top, up to the "fill" line". But the label says, "fill with one quart of engine oil". The pool area that you can see would not hold nearly that much. My carb gets wet with oil. Where is this coming from? Many thanks Peter
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=4666 |
