Fred Hanks | -- 01-30-2012 @ 6:37 AM |
how is the best way to move the doors forward as they touch the body when closed,this is at the handle area,the stricker plate is all the way out??
51f1 | -- 01-30-2012 @ 11:42 AM |
I've moved doors back but not forward which you can do by spreading the hinge using a block of wood. But I believe that the only way to move the door forward is to remove the hinges and straighten them. Good luck. Richard
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=4279 |
