| jimwhite1149 | -- 05-12-2023 @ 7:43 PM |
Can we shim a front axle to help correct "camber"?
| carcrazy | -- 05-12-2023 @ 9:11 PM |
The way to correct camber on a solid front axle is to bend the axle to bring it into the proper specification.
| ford38v8 | -- 05-13-2023 @ 12:04 AM |
Early Fords had but one adjustable on the suspension, that being toe in. If your camber or caster is out, you’re likely to have had a collision with a locomotive. Alan
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=16407 |
