rdouglas | -- 03-14-2020 @ 4:28 AM |
Hi, I own a ‘53 Mercury M-100 (equivalent to Ford F-100) with its original flathead V8 and radiator. While working on the vehicle recently, I noted the radiator cap (which appears to be an after market replacement) is rated for 13 lbs. After doing some research, I believe this is the incorrect pressure and likely too high. Looks like perhaps I should be running either 4 or 7 lbs, based on searching some of the early ford v-8 parts suppliers. Can someone on the forum please confirm the proper spec pressure so I can replace my cap with a correct part? Thank you.
cliftford | -- 03-14-2020 @ 4:14 PM |
I could be wrong, but it sticks in my mind that the fords of this period took a 7# cap.
rdouglas | -- 03-16-2020 @ 11:29 AM |
Thanks for your help
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=13667 |
