denofiniquity
-- 07-27-2018 @ 9:46 PM
Hey guys, the 41 3/4 tn I'm doing has a 2 piece drive shaft. 3 u joints plus a center carrier bearing. Anybody know what "modern" day seals and bearing will work as the carrier?
-- 07-28-2018 @ 6:32 AM
If you can find a seal or part # take the number to Napa Auto parts and they should be able to cross reference it. if they can't do it go to a specialty bearing house.
alanwoodieman
-- 07-29-2018 @ 12:29 PM
took parts for my 41 3/4 ton to NAPA and they pulled them off the shelf u joints mated right up to the 9" rear axle I used, carrier bearing was the same for a long bed pick up thru the 70's
alanwoodieman
alanwoodieman
