BIGTERR | -- 10-14-2015 @ 7:48 AM |
I want to change both the diff. and trans. gear oil on my 47 merc.The trans. takes 90 w, and diff. 140w. All I can find is 80w90 & 85w 140, is it ok to use a multi-grade. Thanks for your help. This message was edited by BIGTERR on 10-14-15 @ 8:37 AM
cliftford | -- 10-14-2015 @ 3:27 PM |
There are several recent posts on this subject. The general consensus seems to be 90w for the trans. and 140w for the rear axle. I would not use anything heavier than that especially if you live in cold weather. I use 85-140 in both and it works fine.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=16&Topic=9077 |
