| SILLAMAN7 | -- 12-19-2009 @ 8:32 PM |
OUR 1950 MERC NEEDS A CARB REBUILD OR A NOS. SO FAR EVERYONE WE TALKED TO WANTS THE NUMBER ON THE METAL TAG. THERE IS NO METAL TAG!! IS THERE A NO. STAMPED INTO THE CARB? ALL WE SEE IS A DATE CODE ON TOP. IT IS A SIDE DRAFT 2 BL HOLLEY. CAN ANYONE POINT US TO A SUPPLIER THAT KNOWS WHAT WE NEED? WITHOUT METAL TAG?? THANKS r/c .
| Tracker | -- 12-19-2009 @ 9:41 PM |
Birdhaven Vintage Auto Supply @ 515-674-3949 can supply the kit you need to rebuild. All you need tell them is automatic or standard shift. Tracker
| SILLAMAN7 | -- 12-23-2009 @ 8:46 PM |
thanks Tracker
| supereal | -- 12-27-2009 @ 9:58 AM |
At one time, perhaps still, you could have the side inlet Merc carb rebuilt by Holley for about $300. There are two versions, one for automatic, the other for stick shift. Those carbs have gotten very hard to find, so a factory rebuild may be the way to go.
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=16&Topic=477 |
