| sq1954 | -- 10-29-2025 @ 10:12 AM |
When adding turn signals to a 1941 front parking lights you have two options. (a) use original single filament bulb using a diode (b) change out to a two filament bulb by using a taillight socket out of a 49-50 Ford. I converted mine to 6 volt LED bulbs to get a brighter light. Remember when converting to LED bulbs you will need to switch out your turn signal flasher to a LED one. Class Tech from Bend Oregon can help you with the wiring harnesses and pigtails.
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=16&Topic=17814 |
