| Mercury8 | -- 12-24-2011 @ 10:23 AM |
Greetings: Does anyone have any info on the correct rubber for the 40-48 Continental coupe: The front doors have stainless window frames that seal against a rubber that is held in place with a stainless retainer that is scr*w*d into the window opening. The rubber currently available is so hard that you cant even close the door if you try and use it. Does anyone know of the correct, softer rubber for this application? Thanks, Alan
| supereal | -- 01-16-2012 @ 7:54 AM |
Try www.lincolnland.com I don't know if they are still around, but it's worth a try.
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=15&Topic=4145 |
