Topic: Emergency brake adjustment
classiclover    -- 11-24-2026 @ 4:59 AM
  Greetings
I just put a new emergency brake cable on my 1940 coupe.. I have adjusted to what I think is tight, but still won't pull the brakes enough to keep car from rolling. I worry about getting it too tight and putting drag on the brakes. Any input appreciated
Dale
carcrazy    -- 11-24-2026 @ 12:51 PM
  Before adjusting the hand brake cable tension, make sure all of the service brakes are properly adjusted. Once you have determined that the rear service brakes are adjusted correctly, do the following.
Place the handbrake lever in the fully released position.
Depress the brake pedal until the rear brake shoes are applied firmly against the drums.
Leave pedal in this position while adjustment is being made.
Pull forward on cables to remove all slack.
Adjust clevis on end of hand brake cable so that, with foot brake pedal applied as above, the end the hand brake lever has 1/2" travel before slack in cables is taken up.
Release the foot brake pedal.
With hand lever in released position, check to make sure that rear wheels are free of any brake drag.
40 Coupe    -- 11-25-2026 @ 4:42 AM
  The reproduction hand brake cables have springs that are too long.
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=18344
