| Barney | -- 11-22-2026 @ 5:33 PM |
Hello All, Many of us believe in, and adhere to, the saying, "If it ain't broken, don't fix it." I recently broke that rule and decided to clean my generator's commutator and brushes. Prior to doing this, my battery indicator needle pointed very consistently rested on the border of the yellow and green arc. It kept the battery sufficiently charged for several years. Upon reinstalling the generator, the needle now points to the very high end of the green arc, even slightly into the red arc. Measuring the voltage at idle measures 8.45-8.5 volts. Consulting a 1940's 'Motor's Manual' tells me I need to slightly bend the armature bi-metal spring inside the voltage regulator module. I'm reluctant to do this for fear of over-compensating or do some sort of damage. Can anyone tell me if this is my only choice? Any suggestions? Advise? Thank you very much. Barney PS The commutator and brushes didn't seem dirty enough to make this much of a difference.
| TomO | -- 11-22-2026 @ 5:39 PM |
Do not try to adjust the voltage regulator without the proper test equipment. You could destroy your generator. Tom
| Barney | -- 11-23-2026 @ 4:17 AM |
Good morning, Tom O. Thank you for your response and advise. It's really what I wanted to hear from an expert; I didn't feel comfortable messing with the regulator, especially since it's been working great for years. I understand that 8.5 volts is a bit on the high side, but is it probable it will not cause any damage to any of the components, except that it may shorten the lives of the bulbs. Hopefully, the voltage output may gradually decrease as the commutator and brushes become dirty again. BTW, prior to reinstalling the generator, I polarized the generator per Kube's advise. I just reread Kube's post regarding high voltage. I noticed he stated to polarize at the regulator. Is there two different operations? Polarize at the generator and polarize at the regulator? Thank you so much, Barney
| kubes40 | -- 11-23-2026 @ 5:49 AM |
Barney, same thing, just a different way of stating it. Sorry for the confusion I added. Mike "Kube" Kubarth
| Barney | -- 11-23-2026 @ 2:30 PM |
Hello Kube, No big deal; thanks for the explanation. I still love ya, Barney
| TomO | -- 11-23-2026 @ 6:33 PM |
Running the generator at a voltage and current higher than it's rating can cause the generator to throw lead. Tom
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=18340 |
