| Barney | -- 11-21-2026 @ 12:49 PM |
Hello Ford Lovers, I recently posted a misfortune my '40 V-8 flathead experienced when the generator pulley separated from the armature. Many thanks to all that responded to my whining about the havoc this caused under the hood. It was very helpful; just ordered the recommended clip. Since I had the generator off, I thought it wise to check the commutator and brushes. All looked reasonably clean with ample brush material remaining. I cleaned both anyway and reassembled the generator. During the previous years I've been driving this car, the battery indicator needle consistently was at the very bottom of the green arc, maybe even slightly touching the yellow. This was no problem; always kept the battery charged. During my first ride since reattaching the pulley to the generator, the battery indicator needle is at the very top of the green arc and very slightly into the red. Battery voltage without the engine running is 6.35 volts. With the engine running at idle speed, the voltage is 8.45 volts at the battery. This seems a bit high. Do any of y'all foresee this as a problem, or is this probably a result of cleaning the commutator and brushes? Comments, advise, etc.? Thank you, Barney
| kubes40 | -- 11-21-2026 @ 3:06 PM |
I'd start by polarizing at the regulator. 8.45v is high. Methinks if it stays at that level, you'll boil the battery. Hopefully TomO will weigh in here. He is super sharp with things that make sparks Mike "Kube" Kubarth This message was edited by kubes40 on 11-21-26 @ 3:08 PM
| TomO | -- 11-22-2026 @ 5:26 PM |
That is high. Do not run the engine until you have your voltage regulator adjusted or replaced. You will damage the generator by running the engine with voltage over 7.8. If it were my car, I would take the generator and voltage regulator to a shop that rebuilds generators and have both checked out. Google "automotive generator repair near me." for a shop near you. Tom
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=18338 |
