Topic: 1940 Ford Cranks but Won't Start/Run
Shiphandling Cowboy    -- 11-16-2026 @ 6:51 AM
  After running beatifully for the 1st year of ownership, I seem to be having a ton of problems with my 1940 Ford Deluxe.
Latest issue is I can't get the thing to start/run
Background: this summer I was having an issue with not being able to restart the car when hot. Even after only 5 minutes of running, if you shut it down it would not restart.
We replaced the ingition coil and condenser - started up and ran fine for a few drives in August. Only complaint I had at that point is that the car would still get hot/approach overheaton the temp gauge when stuck in traffic.
Then in late August I parked the car in the garage and it sat for about 2 months. Only thing unique about the last drive is I brainfarted when I pulled the car into the garage and took my foot off the clutch with it still in gear - car lurched forward as one would and stalled. Since the car was home in the garage at that point, I did not attempt to restart it.
A few weeks ago I went to drive it and it would not start. I think one cylinder fired, but that was it - would not run. For the most part it would just crank and crank. At most every once in a while I'd get one cylinder to fire but that would be it.
6 Volt system - new battery. Confirmed fuel is getting to the carb. Even tried starting fluid. Pulled a plug and confirmed getting good spark. Latest development is that starter will crank just fine to begin with and then it stops/won't turn as if there is too much compression. Release starter wait a second and push again and it will turn over a few times and bog down again.
We're thinking timing might be jacked up. It's a helmet style distrutor. Should I pull the dsitibutor and send it off for service, or is there something else I'm missing?
carcrazy    -- 11-16-2026 @ 9:16 AM
  It might be time to have the distributor rebuilt and set up on a machine by a competent technician skilled in distributor work. Also the starter motor may need new bearings. Check all of the electrical connections in the primary ignition system and the starting system. There may be contaminants in your fuel system.
JayChicago    -- 11-16-2026 @ 9:16 AM
  Guys. Please don't guess and send the poster down a dead-end. Before you jump on the keyboard to post your idea on this, please think if your idea is consistent with his symptoms:
"6 Volt system - new battery. Confirmed fuel is getting to the carb. Even tried starting fluid. Pulled a plug and confirmed getting good spark. Latest development is that starter will crank just fine to begin with and then it stops/won't turn as if there is too much compression. Release starter wait a second and push again and it will turn over a few times and bog down again."
carcrazy    -- 11-16-2026 @ 10:45 AM
  You may have coolant or another liquid leaking into the cylinders causing increased compression or a temporary hydraulic lock.
Remove all the spark plugs and crank the engine to see if anything comes out of the spark plug holes.
Check the compression in each of the cylinders.
Shiphandling Cowboy    -- 11-17-2026 @ 4:58 PM
  It does not appear to be a hydraulic lock. When you crank the starter with the ignition off it does not slow down/ stop.
I somehow managed to get it to run briefly tonight. But in that brief period (roughly 30 seconds) noticed that the car was shaking side and not running smoothly. It was as if the cylinders were not firing in proper sync. Eventually the engine died.
Is there anything else to check before pulling the distributor?
carcrazy    -- 11-17-2026 @ 9:09 PM
  Are both of the distributor caps on tightly? If one of them is loose, the car will only run on 4 cylinders.
This message was edited by carcrazy on 11-17-26 @ 9:10 PM
ford38v8    -- 11-17-2026 @ 10:18 PM
  JayChicago makes an excellent point. The OP has offered multiple good clues and his own thinking on the causes. Thinking out of the box works sometimes, but study the clues for an educated guess!
RAK402A    -- 11-18-2026 @ 4:19 PM
  Bravo on keeping your car on 6 volts!
I have been through what you are experiencing, or variations of it.
All of what I post below has been learned from the people on this forum over the years...
Assuming there is no mechanical issue or hydro-lock causing the cranking issue, make sure that ALL of the connections for the battery are absolutely clean and bright (battery terminals, ground straps, solenoid connections, and the area where the starter bolts to the oil pan (there should be no paint on the area of the oil pan and starter where they come together). I have had issues with slow cranking gradually stopping and it was always due to battery charge condition or the contact areas that I mentioned above not being cleaned (I once changed a starter due to symptoms similar to those you have described and it was only dirty ground contacts...).
On the starting issue...
It sounds like you are certain it is getting fuel, so I would look at the ignition.
Put the car in neutral with the parking brake on. Pull off one spark plug wire at a time and hold it near one of the cylinder head nuts (these nuts should be clean and not painted). While cranking the engine with the ignition on, look for a bright blue spark about 3-1/2 inches long at each plug, that will tell you if you are getting a good spark. BE VERY CAREFUL AS YOU CAN GET A PRETTY GOOD SHOCK WHEN DOING THIS (you can guess how I found that out).
If you don't get a good spark at all plugs, you will want to go through the ignition system methodically, to make sure that you find whatever is causing the issue-bear in mind, there may be more than one issue.
1) Make sure that you are getting full battery voltage to the ignition switch-this is easily measured due to fact that the terminals on the switch are exposed.
2) Next, make sure that you are getting the same voltage coming out of the switch (if you have never done it, it is very easy to take the switch apart and clean the contacts).
3) Next, make sure that the same voltage is getting to the input side of the ignition resistor.
4) Now make sure that there is voltage coming off the other side of the ignition/ballast resistor (forgive me, I think this should be 3-4 volts but I am sure that someone with more knowledge can confirm or deny this). REPRO IGNITION RESISTORS CAN EASILY GO BAD OR BE BAD-EVEN WHEN BRAND NEW (you can guess how I found this out-intermittent and drove me crazy trying to find it).
5) Make sure that the same voltage that was present on the output side of the ignition/ballast resistor is present at the top terminal of the coil.
6) Remove one of the distributor caps and look at the brush coming down from the bottom of the coil-is it making good contact with the brass ring around the rotor? Is the ring clean? Is there good tension on the brush (this one has gotten me too).
7) If you have a reproduction coil (the one from the well known parts manufacturer), be inclined to suspect it. I have had one go completely open on the high tension side. These also have issues with internal resistance when the car is warmed up, effectively preventing starting (this is frequently confuse with vapor lock as when the coil cools down the car starts). I found out about this one the hard way too.
8) Assuming the coil is good, check the rotor to make sure it is in good shape and the aforementioned band where the brush from the coil touches it is clean. Make sure that the two metal tabs on the rotor where the spark jumps to the caps are clean and bright. A wire brush on the Dremel tool helps here.
9) Check to make sure that the brass ends of the ignition wires are clean and soldered to the ends of the wires (stock wires should have solid conductors). Make sure that the contacts on the inside of the caps where the spark jumps across are clean and bright. Make sure that the inner caps are clean with no burn marks on the contacts of the Bakelite. Make sure that the correct gaskets are installed so that the gap between the contacts on the inner caps and the tabs on the rotors is correct.
Someone above mentioned having a skilled person go through the distributor. If all of the above does not provide the answer, that is the next thing I would do. It is very easy to remove the distributor. These distributors very easy to work on if you know how to do it and want to get into it. If not, I would send it to someone who is reputable (Skip Haney). If the coil is bad (the repro's are consistently bad, IMHO-I have had many of them in the last 50 years), I would get an original coil and send it to Skip Haney for a rebuild (Skip Haney's coils completely fixed my hot start issue).
Sorry to be long winded.
Again, I learned the above from the people on this forum over a period of years (who know a great deal more about these things than I will ever know).
You car should crank like this with a good 6V battery (mine is an AGM battery, I believe): https://youtu.be/V3fTPME2eME?si=muHwEc6Tgk71lEUM
This message was edited by RAK402A on 11-18-26 @ 4:20 PM
TomO    -- 11-22-2026 @ 5:37 PM
  If the engine cranks normally with the ignition off and buck with the ignition switch on, you have a timing issue.
Check the rotor for rotational looseness. If it is OK, remove the distributor and use your cell phone to take a photo of the timing gear. Check to make sure the index marks are lined up. Your timing gear could have shifted when you last drove it.
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=18335
