| 40merccoupe | -- 11-14-2026 @ 10:29 AM |
Anyone have a tip on how to get the upper rear main seal out of the engine? I have a rear main seal remover & installer tool. I took the rear main cap off & loosened the other main caps. I scr*w*d the remover tool into the modern seal & per instructions with the tool started to rotate the crank to pull the seal out, but it won't budge and it started to rotated the upper bearing out. This message was edited by 40merccoupe on 11-14-26 @ 10:31 AM
| carcrazy | -- 11-14-2026 @ 3:31 PM |
There are two pot metal pieces into which the rope seal fits. The upper piece, #91A-6335 fits into the cylinder block. If you can't get the old rope seal out of this pot metal piece, you can try using some penetrating oil to loosen the rope seal. If this doesn't work and you are willing to drop the crankshaft far enough to get the upper pot metal piece out of the block, you can soak the pot metal piece in lacquer thinner to get the rope seal to release from this piece.
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=18332 |
