Topic: Heater hose
gwistrup    -- 11-01-2026 @ 7:01 AM
  Are there any recommendations for heater hose that is like the original? I bought some OEM style hater hose clamps that seem too big for the standard generic hose. Or should I get smaller clamps? Thanks, Gil
carcrazy    -- 11-01-2026 @ 8:19 AM
  The standard 5/8" heater hose should work fine on your Early Ford V-8. Provided you are not concerned about being correct for show purposes, you can use the modern screw type of heater hose clamps which will function and provide a leak-free connection.
kubes40    -- 11-02-2026 @ 5:29 AM
  Heater hoses were cord reinforced black rubber and had no identifying markings. While the inside diameter was a nominal 5/8”, the outside diameter was
approximately 1”. This outside diameter provided a seal against engine noises entering the vehicle when the hose was pushed firmly through the dash panel (firewall) holes provided for the heater core tubes.
Modern hose, with a nominal inside diameter of 5/8”, most often has a smaller outside diameter. Consequently, it will not provide the intended seal against
engine noises.
You might try McMaster-Carr. Lacquer thinner will remove any ink from modern hose. Here's the link to what you want. They are super good to deal with.
ID 5/8" OD 15/16" REINFORCEMENT Yarn Color Black ITEM NO. 7879N36 price per foot 3.38
This message was edited by kubes40 on 11-2-26 @ 5:33 AM
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=18319
