Topic: 6V LED headlights
Barney    -- 10-12-2026 @ 3:28 PM
  Greetings to All,
I have a 1940 Standard that I often drive at night, even more so now that our daylight hours are fewer. As I'm sure you're aware, the original style 6V sealed beams are quite anemic. Is there such a product that produces LED brightness and will fit into the original headlamp bucket. It doesn't need to look original; I just want ample light to see and be seen. Thanks for any suggestions or comments.
Sincerely,
Barney
carcrazy    -- 10-12-2026 @ 4:06 PM
  You can install a headlight relay to increase the brightness of your stock 6V headlights.
One source for these relays is Fifth Avenue
https://fifthaveinternetgarage.com/electrical_parts.php#blower
Barney    -- 10-12-2026 @ 6:09 PM
  Carcrazy,
Thanks for the info. I'm a bit puzzled what a relay would offer, but I'll take a peek at the site. Maybe energizing both the high and low filaments simultaneously. Thought of that months ago, but thought there may be a overheating issue which would probably drastically shorten the bulbs' lives. Again, thanks for the info.
Barney
TomO    -- 10-14-2026 @ 12:12 PM
  A head light relay increases the voltage to the headlights if you have resistance in the headlight circuit. This resistance can be in the headlight switch, dimmer switch or connectors. The headlights are considered 7 volt bulbs that need at least 6.5 volts to give normal brightness. Your generator should be putting out 7.4 volts when driving and your headlights should see battery voltage when idling.
If you have at least 6.0 volts at your headlight bulb, with the engine off, you are getting the maximum light your bulb are able to provide. A headlight relay will not help you. Bulbs give off less light as they age, so new bulbs may help. Having the bulbs aimed will also help. The sealed beam bulbs give off a yellow light which is seen as dimmer than the white light given by LED bulbs we have on our modern cars.
If you have less than 6 volts at the headlight bulbs, the most common cause of low voltage is the dimmer switch. You can try operating it several times ( at least 50) to see if that brings your voltage up.
As we age our eyesight also dims. Check with your eye doctor about the condition of your eyesight in low light conditions.
If you and your car pass all of the necessary conditions for bright lights and you still need something brighter, try anAI bot to find the best option for LED lights for you. Let us know how you make out, there have been so many new options since I last checked for LED headlights in 2022, I would like to know how someone solves the problems of fitment and apperence.
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=18299
