| classiclover | -- 08-06-2026 @ 1:13 PM |
Greetings gents I just returnd from a trip after being gone for the month of July. My 40 wont start. Put gas in the carb several times and it runs until gas is used up. Pulled fuel line of carb and turned it over, no gas comes out of the line at all . Pulled fuel line off fuel pump, put my finger over the opening in fuel pump and turned it over. Cant feel any pressure at all on my finger. So need advice on what to do next. Maybe it is the fuel pump. Not sure how to check. Should I try to blow air back down the fuel line. I think I should hear some gurgling if I took off the gas cap. The car was running very well when I parked it for 30 plus days, and of course it has Ethenol gas in the tank and I know better Appreciate any suggestions Dale
| carcrazy | -- 08-06-2026 @ 1:54 PM |
Are you sure you have enough fuel in the gas tank? If there is no pressure in the pump outlet line when you crank the engine over, the diaphragm in the fuel pump may have failed or one of the one-way check valves in the pump may have fallen out. Please let us know what you find.
| classiclover | -- 08-06-2026 @ 3:27 PM |
Thanks Is there any way to check if the fuel pump is working or is there a block in the fuel line from the tank
| kubes40 | -- 08-06-2026 @ 6:16 PM |
To test with the pump on the car: disconnect the flex line and install a nipple fitting in the pump. If you don't have one, go to NAPA. Run a rubber hose from the nipple into a can of fuel near the pump. The pump should pick up the gas promptly if there is a clog in the line from the tank. If it doesn't most likely a defective pump. Mike "Kube" Kubarth
| classiclover | -- 08-07-2026 @ 6:13 AM |
Thanks gents All things point to the fuel pump. Not sure why as car was running great before it sat for a month. I looked on Dennis Carpenter, but couldnt find one. Any suggestions on best place to buy one appreciated Dale
| 51504bat | -- 08-07-2026 @ 6:35 AM |
Joe's Antique Auto is my go to source for parts for my '39 p/u. https://www.joesantiqueauto.com/fuel-pump-59a-9350 It's listed as out of stock but might be worth a call to see if it might be back in stock or Joe might have a suggestion of who might have one in stock ______________ No signature
| carcrazy | -- 08-07-2026 @ 1:34 PM |
If you can't find a complete fuel pump for your car, you might want to order a fuel pump rebuild kit and just rebuild your pump. C&G has these kits in stock. https://cgfordparts.com/products/fuel-pump-rebuilding-kit-34-48-pass-39-48-merc-34-47-pu-v8-with-glass-bowl-11a-9349?_pos=13&_sid=40b62d78d&_ss=r&_fid=5cf876a2f
| classiclover | -- 08-08-2026 @ 4:58 AM |
Hello again Will I need to get a new fuel line from pump to carb if I cant find the same pump that is on the car
| 40 Coupe | -- 08-08-2026 @ 6:21 AM |
Send your pump to Charlie Schwindler in Orchard Park N.Y. He rebuilds and test for proper flow and pressure.
| carcrazy | -- 08-08-2026 @ 8:55 AM |
Many vendors offer fuel lines that you can bend to make into the proper configuration to fit your combination of fuel pump and carburetor. If you have an inexpensive tubing bender (available at your local auto parts or hardware store), you can also bend your old fuel line to fit properly and be leak-free.
| classiclover | -- 08-08-2026 @ 12:31 PM |
Thanks to all for the help Greatly appreciated
| TomO | -- 08-08-2026 @ 2:30 PM |
The fuel line from the pump to the carb is bent the same way for either the pump without the glass bowl or the one with the glass bowl. C&G ford parts sells a pre-bent line. The pumps without the glass sediment bowl seem to be no longer available. If you have one, send it to Charley for rebuilding. You can buy one with the glass bowl from RockAuto .com Tom
| classiclover | -- 08-10-2026 @ 10:17 AM |
The steel bowl carb is not available. Is the glass bowl completely interchangeable with the fuel lines Dale
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=18211 |
