| Pat69 | -- 07-19-2026 @ 2:18 AM |
Hi I just tried to remove the Starter which did not engage and just the housing came off, the Rotor is stuck somewhere on the inside. I turned and jiggled around but it won't move and I dom't wanna force too much on it..... Did anybody have the same Issue Patrick
| TomO | -- 07-22-2026 @ 6:25 PM |
Patrick, If the end plate is free, try turning the engine over backward with a socket on the crank pulley. If you can't get a socket on the pulley, put the car in 3rd gear and push it backward about a foot. If you hear a loud bang, that will be your starter being freed from the flywheel. Tom
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=18178 |
