Topic: Dash lights brightness adjusting switch
classiclover    -- 06-23-2026 @ 11:34 AM
  The adjusting switch for the dash lights will no longer work on the brightness. I need to increase brightness, but turning the knob on the switch no longer works. I know I can replace the switch, but before I do that, I was curious as to any easier method . Thanks much
Dale
nelsb01    -- 06-23-2026 @ 12:14 PM
  The switch is probably a rheostat design, and it could be dirty in the rotating switch.
Try giving it a cleaning.
kubes40    -- 06-23-2026 @ 5:25 PM
  The dash lamps, even at their best, are not what I'd call "bright".
I suggest you bypass the rheostat completely. Even a new one will draw some power from the bulbs.
Simply solder a small "jumper" wire between the two terminals or easier yet, connect the two wires (currently connected to the switch) together.
classiclover    -- 06-23-2026 @ 9:46 PM
  Thanks much gents Appreciate all the help I can get
Dale
40 Coupe    -- 06-25-2026 @ 5:41 AM
  OR replace the two dash lights with LED light bulbs, after cleaning the switch/rehostat with contact cleaner.
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=18151
