Topic: Crab style distributor replacement
gwistrup    -- 04-11-2026 @ 10:24 AM
  I knew the engine in my 1940 Tudor Sedan was not the original when I bought the car and now I have finally figured out that it is a 1942 Mercury 100 HP flat head. The biggest visible giveaway compared to the original engine is the crab style distributor. I don't want to upset the purists, but if I put a diver's helmet distributor on my Mercury engine, it would look more original. Can I put an older 3 bolt timing cover in place of my 2 bolt timing cover so I could put the diver's helmet distributor on my newer engine? Is the drive at the end of the camshaft the same?
TomO    -- 04-11-2026 @ 10:43 AM
  Yes you can. You will also have to buy an adapter that will fill the space from the shorter camshaft nose. Most vendors carry the adapter.
ford38v8    -- 04-11-2026 @ 11:23 AM
  To add a detail to Tom’s advice, the timing cover will require a rope seal (half) replacement, a simple enough task, they do come with specific instructions.
carcrazy    -- 04-11-2026 @ 3:59 PM
  You can get everything you need to do this swap from VanPelt:
Camshaft to distributor adapter - 11A-6280
1932 to 1941 3-bolt distributor mount front cover (NOS) - 18-6019
Rope seal upper or lower - B-6700-A
gwistrup    -- 04-12-2026 @ 7:26 AM
  Thank you. I was just on the phone to Van Pelt's last week looking for some bearings and rings. They sent me to Red's Vintage Parts. I will call them back.
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=18073
