| dustinhoffner | -- 08-16-2025 @ 7:39 PM |
Does anyone know to remove the ignition lock cylinder on a 47 Ford Super Deluxe?
| trjford8 | -- 08-17-2025 @ 8:43 AM |
Look on the bottom of the steering column bracket just below the lock mechanism. You will see a pin that is just below the lock. That pin needs to be removed to get the lock out of the bracket. You can drill out the pin or drill a small hole in the center of the pin and use a slide hammer to pull out the pin. Once the pin is out the lock will come right out.
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=17721 |
