46fordnut | -- 08-31-2015 @ 4:14 PM |
just a quick question . i forgot how long to charge my 6 volt battery for using a 6 amp charger . battery states 640 cca 130 reserve another number said 800 if you people can help id be greatful. thank you in advance valve covers can't leak if they don't exist .
cliftford | -- 08-31-2015 @ 5:31 PM |
It depends on how far the battery is discharged. If its a lead acid battery, check it with a hydrometer, each cell should read about 1.260 to 1.275 at full charge. Its an optima, or other sealed type battery,check it with a volt meter and it should read about 6.5 to 6.8 at full charge.If it is completely discharged, it will be difficult if not impossible to bring it back to full charge. In any event, it may take several hours.
46fordnut | -- 08-31-2015 @ 6:09 PM |
not fully discharged just little weak . cranks slower than the normal . valve covers can't leak if they don't exist .
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8920 |
