40topless | -- 07-01-2015 @ 2:50 PM |
Is there any old hot rod secrets out there for installing a dual carb intake. I do not want to drill a hole in firewall for fuel block. Is there any other way of doing it?
carcrazy | -- 07-01-2015 @ 3:08 PM |
Yes! You can make your own fuel line from the pump to the carbs by using 1/4" bulk fuel line (copper or steel) tubing, six brass fuel line fittings, six ferrules, and one "T" fitting. The setup works quite well and doesn't require drilling any holes in the firewall or inner fenders.
40 Coupe | -- 07-02-2015 @ 4:24 AM |
There is different hardware available for the Stromberg and the Holley. Carb. Suggest you look on the Stromberg web site or the Vintage Speed web site. You do not have to run a fuel block, or increase the size of the fuel lines, unless you desire to.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8688 |
