murphy 1941 | -- 08-21-2014 @ 6:56 PM |
I've checked almost everything and know I'm still learning about flathead engines and have a long way to go. I need you guys to again help me with some ideas as this is a brother type site and you have made me feel just like that by your past assistance. Thks John Early Super Deluxe 41 Coupe
4dFordSC | -- 08-21-2014 @ 7:13 PM |
In what gear? Are you downshifting to second?
murphy 1941 | -- 08-21-2014 @ 8:20 PM |
I come to red light it turns green and I step on it and she bucks or when I turn corner and she drops to about 15 she bucks Early Super Deluxe 41 Coupe
murphy 1941 | -- 08-21-2014 @ 8:21 PM |
Yes then I have to shift into second Early Super Deluxe 41 Coupe
murphy 1941 | -- 08-21-2014 @ 8:22 PM |
Yes then I have to shift into second from third Early Super Deluxe 41 Coupe
4dFordSC | -- 08-21-2014 @ 9:01 PM |
It's normal for the car to buck in third gear at speeds below 20 mph, and for that reason it's best to downshift into second at around 25 mph.
murphy 1941 | -- 08-22-2014 @ 5:16 PM |
Ok thank you , below 25 shift to second. Woe worn model a this wouldn't happen it would pick right up. Thanks again I feel better about it. I thought compression problem John Early Super Deluxe 41 Coupe
supereal | -- 08-23-2014 @ 11:32 AM |
Look down the carb throat and watch for fuel jets in both barrels as you work the throttle, If weak, or one side doesn't show a jet of fuel, the accelerator pump in the carb is not working, This can be from alcohol fuel attacking the pump, or the stroke adjusting link on the side of the carb being loose or not connected. If the car has backfired, the power valve diaphragm is likely damaged.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=7643 |
