eli33 | -- 04-17-2014 @ 5:00 PM |
Had my dad's 35 Ford worked on this week and discovered the left head has a hairline crack we never noticed. Can these be repaired or do we need to locate a replacement?
BrianCT | -- 04-17-2014 @ 6:07 PM |
Can't say about repair without more information. Used heads are available. Is it aluminum or cast iron? Is there a part # cast on the face? If you do go the replacement route, make sure to use a head with the same part # .
eli33 | -- 04-17-2014 @ 6:24 PM |
Aluminum. Car is in shop so am not able to check for part no.
supereal | -- 04-17-2014 @ 7:34 PM |
Aluminum can be welded, but heads are not candidates. The compression and the interior erosion are big factors. It is much better to find a replacement. They are out there.
eli33 | -- 04-17-2014 @ 7:44 PM |
I appreciate the advice.
ken ct. | -- 04-17-2014 @ 11:03 PM |
Try John Mason 1-410-658-6294 , I know he has some he would need part # on other side to match up. ken ct.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=7238 |
