efv8 | -- 06-13-2012 @ 5:46 AM |
For those that search the Early Ford V-8 Forum for entries, there has been a clarification added to the 'In the past' field. Prior to the change, once you entered your 'Keywords' and used the pull down menu for 'In the past', you saw the following: blank, 2 days, 5 day, 10 days, 20 days, 30 days, 60 days, 90 days, 120 days, 365 days. The 'blank' was previously available for ALL. That was unclear unless you accidentely clicked on it. Starting 6.13.2012, the 'blank' has been replaced with the word ALL. We hope this helps you in your searches, and clarifies the use of the Early Ford V-8 Forum. Please also note, that if you enter your Username in that field, you will only see entries that you submitted. Leave the Username field blank to see all entries from your Keyword search. Bruce Nelson Early Ford V-8 Club Web Administrator This message was edited by efv8 on 12-12-14 @ 5:54 AM
murphy1936 | -- 12-28-2013 @ 7:47 PM |
Thank you for the maintenance you provide on this web. Happy New YEAR JOHN Super Deluxe 41
umarsahb | -- 04-02-2015 @ 5:52 AM |
Please also note, that pass4sure 642-447 if you enter your Username in that field, you will only see entries that you submitted. Leave the Username field blank to see all entries from your Keyword search This message was edited by umarsahb on 4-2-15 @ 5:53 AM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=4792 |
